| | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | My Speedglass Utility helmet I have for MIG isnt rated for TIG. Anyone have recommendation of what to buy/not buy? My usage will include low amp for sheet metal. Thanks
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2004 Posts: 29,820 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,820 | I TIG welded literally miles of 4" thinwall stainless steel tubing when I worked for E&J Gallo winery in California, using a plain old #11 lens in a conventional welder's hood. What is the reason your current hood supposedly can't be used for TIG? For the past 10 years or so, I've used an auto-darkening hood from Harbor Freight- - - -their higher priced one with adjustable darkness and response time. The only difference I've been able to see between stick welding and MIG or TIG is the fact that there's little to no smoke, requiring a slightly darker lens to filter out all the harmful light. Jerry
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | The documentation that came with the hood lists only MIG and Stick for the "Utility" hood, which is what I have. TIG is listed under other models. Doesn't really say why. I suspect switching speed or shading, but don't really know. The shading is 10.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2016 Posts: 148 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 148 | Dennis,
The 3M Speedglass helmets are some of the finest money can buy. I'm also curious why the helmet you have is rated for only Mig and Stick. I'm not able to think of a reason a helmet rated for Mig and Stick, couldn't be used for TIG. I did some searching, and I can't find anything about it. Sorry I wasn't any help.
David
-David
1953 2-Ton GMC
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Have no answer but being a red head (now grey) I had to have a helmet that covered my shirt neck opening when TIG welding or end up with a two tone chest. Not so much so with mig or stick.
Evan
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | A #10 lens is a #10 lens, no matter what type of welding. The automatics are nice because most of them can be adjusted to a higher numbered or darker lens. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks for the feedback. I've found the switching time is .65ms for the one I have and the others produced at that time are from .15 to .4. However another model is also rated at .65 so guess that is not the major factor. I've made up my mind to get a newer one anyway. Some of them are rated by the minimum amps you are going to use. Not sure what my min amps will be. I have a lot of research to do yet.
Dennis
40 Chevy 1/2 ton
