2 members (dt235sd, 1 invisible),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I installed a 1.25” bar from a C30 on my 1965 C10 about 3 years ago. It really holds steady in the corners. My 1963 C10 has a 1 + 1/16” bar and is less steady but still good. Here’s the info. LINK to Anti-sway bar info.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Now that is a great article Lugnutz, great details and photos!  I needed all of that information about this, 10 years ago. I added it to my pile of stuff about sway bars: sway bar options for 1960-1966 Chevrolet/GMC trucks-Woog | | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Great info and illustrations.  Thanks for sharing. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | You have just added another thing to do to my truck.  | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Back in my sports car obsession days, we had an assortment of front and rear antiroll bars for the Datsun roadster we campaigned at various autocross and gymkhana competitions in central California. Depending on the layout of a particular course, we would swap bars to change the handling characteristics. Maybe it helped- - - -we won a lot of class trophies and a few "overall best time" on the short, twisty ones. Jerry
| | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | Great How-To. I'm looking at the pictures and trying to visualize the suspension on my straight axled '51. Hummmm
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Two friends local to me are coming over Saturday morning for an “anti-roll bar installation party”! Such fun! | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Will this work for a 1960 with torsion bar suspension? | | | | | Joined: Jul 2000 Posts: 2,198 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,198 | My Dad had a '63 Chevy truck. One end of the anti-roll bar broke loose on the Alaska highway - we were miles from anywhere. Dad took one of the muffler clamps off and used it to hold the bar in place. That rusty old clamp didn't last long, but it was enough to get us to a place where we could buy a new one.
There is a lot of force on an anti-roll bar.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | My Dad had a '63 Chevy truck. One end of the anti-roll bar broke loose on the Alaska highway - we were miles from anywhere. Dad took one of the muffler clamps off and used it to hold the bar in place. That rusty old clamp didn't last long, but it was enough to get us to a place where we could buy a new one.
There is a lot of force on an anti-roll bar. I’d be interested to know where the anti-sway bar came loose. The anti-sway bar that I have installed is from a square body truck. It is not common for them to fail. Obviously the brackets and bushings must be kept in good shape and properly lubricated. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Will this work for a 1960 with torsion bar suspension? The lower control arms do not have pre-drilled holes from 1960—1964. Otherwise, they should bolt up the same as the 1965—1966 trucks. | | | | | Joined: Jul 2000 Posts: 2,198 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,198 | It broke off where it attached to the driver side a-arm. This trip was before the highway was paved - it was pretty rough back then. We were carrying a heavy camper.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Jay, That C30 bar you describe - what years would this bar be found? 63-6xx or 60-6xx?
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Jay, That C30 bar you describe - what years would this bar be found? 63-6xx or 60-6xx? I have only seen one 60-66 C10 with a swaybar. I bought a parts truck and it had a tiny 0.75” sway bar that looked original. Probably was a dealer option add on. Look for a sway bar from a 73-87 square body truck. C10 will be 1+ 1/16” and C30 will be 1.25”. You will also find them on Suburbans too, same years. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | The Suburban (62) - that is the application I am thinking. I will start a search this spring. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | The Suburban (62) - that is the application I am thinking. I will start a search this spring. Your 1962 will not have pre-drilled holes in the lower control arm but it is not difficult to measure to find the proper location. Drilling the holes gets a little cramped, so a right angle drill is helpful. | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | An antiroll bar is spring steel- - - -basically a side to side torsion bar to resist body lean in turns. Going to a much larger diameter bar than original will result in a lot of ride roughness if only one wheel hits a bump or drops into a pothole. It will also transfer a lot of stress to the frame rails ahead of the front suspension crossmember. Handling in turns will also be radically different, so educate yourself on what to expect by pushing the envelope a little where it's safe to do so. Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | An antiroll bar is spring steel- - - -basically a side to side torsion bar to resist body lean in turns. Going to a much larger diameter bar than original will result in a lot of ride roughness if only one wheel hits a bump or drops into a pothole. It will also transfer a lot of stress to the frame rails ahead of the front suspension crossmember. Handling in turns will also be radically different, so educate yourself on what to expect by pushing the envelope a little where it's safe to do so. Jerry You confirm what I told a friend. When you hit a pothole with only one tire, the suspension for that front wheel compresses. The anti-sway bar moves with the suspension but the opposite side suspension resists the movement. So it’s like hitting the pothole with stiffer front springs (like double springs) because both front springs are in play. That being said, it stays rock solid around hairpin turns. I have a 1.25” C30 bar on my 1965 but the 1 + 1/16” bar on my 1963 is just fine too.
| | | | | Joined: Jul 2000 Posts: 2,198 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,198 | If the anti-roll bar is too big/stiff, the inside wheel might lift off the ground on hard cornering which could make handling worse. Not that you will be driving an old truck trough a slalom course ...
Anyway, I installed a bar on the '54. Big improvement in handling - who needs IFS!
