3 members (panic, 2-Ton, 1 invisible),
133
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Need identification for a stovebolt 0170757 F56Z
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | F56Z 1956 Chevrolet car serial numberF = Flint, MI engine plant 56 = 1956 Z = 6 cylinder manual transmission (car) engine (it will have hydraulic lifters) | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Thank you Tim. The engine is in an auction near me. No one has bid on it. Starting bid is $5. Engine is complete minus the air cleaner. Includes the bellhousing and flywheel. Thinking about it.
Rick
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | rickmg Would jump on that,just think of the pleasure you'll get out of climbing over it in your shop LOL !! Seriously,if not stuck lotta good stuff there,look close for freeze cracks,see if it will turn full revolution!!! | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | You're spot on about climbing over engines, etc. in the shop. Got a Ford Model A engine that a guy purchased from me 5 years ago for $25 and never picked it up. A 1938 216 Chevy engine, a Mercury boat motor, Jiffy Ice Auger, 1997 Ford Ranger automatic trans. No need for any of it. Thinking about scrapping the 216 and automatic trans. If the 216 in my 39 stake truck becomes a problem, I'll probably replace it with a 235. I've had several 235 engines and gave them away.
Rick
| | | | | Joined: Feb 2008 Posts: 1,134 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,134 | | | |
