8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 95 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 95 | Checking out an engine from local ad. From the numbers so far I` ve deduced its a 235 from 58 to 62 out of a car w/powerglide. Guy says it was rebuilt and never installed...been sitting in his shop undercover for 30 years. $500.00 It`s a 30 mile drive over to check it out but he could be negotiable on the price. Pics don`t look all that great so I wanted to see for myself. Also check out if it`s got oil in it (says it turns over) what parts are there etc. I`ve chased a few of these motors and currently have a couple That I`m starting to spend time on. One 62 with solid lifters that likely needs a rebuild and a 58 that very possibly needs a broken ring replaced. Without bringing it home and putting it on the run stand, is there any other items I could check out to help confirm it`s worth risking money and possible banishment to the shop over?
1953 3100 Pu
| | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | I think I seen that on Facebook .it looked suspicious in the picture that was posted as in the comments it was dirty and greasy . I would check for new gaskets ,take valve cover off .receipts | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Take a battery and jumper cables and a spark plug wrench. Take your compression gauge. If the guy will let you do a basic compression test. It can be done with the engine setting on the floor.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Swami29 Better spray the valve guides and be sure they are free,if you do the compression test,also watch for muddobber nests. Would give it some marvel mystery oil to help ! In the cylinders before compression test.
| | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | Is the guy named Barnum? I would be extremely suspicious of that one, unless he's willing to go to the effort to let you hear it run. No, don't put a lot of work into it yourself- - - -either insist that he put it in running shape or ask for a BIG discount! I'm waiting for better weather to make a road trip to pick up two FREE 235's. Jerry
| | | | | Joined: Apr 2020 Posts: 322 Professional procrastinator | | Professional procrastinator Joined: Apr 2020 Posts: 322 | How about an inspection camera in the spark plug hole to look at the cylinder walls. That would settle it real fast.
1947.2 GMC 1/2T SWB panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T short bed
| | | | | Joined: Sep 2019 Posts: 164 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 164 | $500.00 seems a bit steep for a 235. They can be found for less.
I invest my money in precious metals, mostly rust!
| | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | $500.00 seems a bit steep for a 235. They can be found for less. A good running 235 for $500 would be a good deal. A complete engine that needs to be gone through should be in the $75-100 range. Just my opinion, based on what I see here in the Midwest. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
