1 members (Hotrod Lincoln), 69 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
I'm looking for 2-3/4" wide silicon carbide sandpaper rolls for my IR inline sander. Dont need PSA or Hook and Loop . Has anyone found a reasonably priced source for this material and can post here?
Question two - what would be the starting grit to sand down first and second coats of filler? and then to smooth-and blend in in afterward?
Perhaps - outline what sanding steps you take to smooth out a roof and back of a cab?
Appreciate the help.
Thanks.
Tom
1946 GMC Project
"Back-in-the-day Restore"
Try TCP Global for the sandpaper rolls.
Roughing out filler, I use 80 grit. 220 for smoothing, and then 400 or finer for final sanding before paint.
Try Auto Body Toolmart located in Elgin ,IL
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that stuff on everything"
H Online: Content
Ebay has "Long Board Sandpaper" in either rolls or pre-cut strips- - - - -around 500 listings. There's plain back, self-stick, and hook and loop types. I used to use 40 grit for roughing out filler and 80 to 320 grit for progressively smoother finish work.
Thanks for the help, guys.
tom
1946 GMC Project
