1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I went to pickup a less than $300 truck yesterday. It was a 2 ton 137" wheel base dump. I just wanted it so I would have a frame to start with. But after looking it over I figured out it was at one time a 161" WB and had the spring hangers cut off and moved forward, with some ugly cutting and welding.
And I drug an empty trailer back home.... So, I am still looking for a frame, and, or a cab. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | That's a project I'd like to see complete. Very interested in it. Me and my bud who's the exec director at the local railroad museum were playing with a 4-53 generator set on an old pullman car during the state fair in october. He drives a 60 1/2 ton daily and said he's rebuilt so many 4-53's that he could do one blind folded and in his sleep. The 4-53 ran great if a bit noisey. What did you give for yours? I think both of us would like to give that a try.  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I gave $2,000 for a complete running driving and dumping 78 gmc 6500 dump truck with a 4-53T. I would have given much less if it did not have a turbo. Actually I would not have bought it if it did not have a turbo. I then pulled the engine and trans and sold the rest of the truck. I'll keep yall posted as I move along, looks like in a few months I will drive to SD to pickup my frame and cab, should move faster from there.. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | woo hoo.
This is getting interesting.
-W | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | In about March I will go get my "new truck", it'a a 48 6100 with a 5 window cab, with very little rust. And I have also found the transmission I will run. It's a Fuller Roadranger RTO-6613, that's the newer version of the small 13 speed overdrive. I will probably only use the top 4 or 5 gears, but the extra low ones, like about 14:1 or so, might be helpfull with a heavy load, or backing up a trailer, or ringing off 1.5" axle shafts and such. I'll probably go get the trans on the way to or from getting the truck, if not sooner.
Any one have any heavy duty engine mounts that they can recomend for easy swaping to something else, like Mack engine mounts, or something else? I don't have a big truck junk yard to go look at and see for myself what I can use... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | |
