5 members (Dusty53, fonz8261, Stovebolt48, 1955 1 Series, DHedrick), 308 guests, and 6 robots.
Topics128,158
Posts1,057,023
Members48,460
For the 1st time in 28 years or so, I left my '48 sit outside for much of Fall and Winter. I'm getting things going again but there is very little braking. The pedal feels fine but when stomped very hard, it doesn't screech to a stop like it would before. It glides to a stop.
The master cylinder was new last year. It's cold and snowy enough that I don't want to do a complete brake job outside now but I would like a hint of what's wrong so I can dream of fixing it.
Can an MC freeze up with 5 months sitting? Or maybe 3 out of 4 wheel cylinders freeze up? I should have gone outd and worked the brake pedal every so often.
Thanks!
Rust on the drums? Maybe it'll get better after a few stops?
Obviously check for leaks Jack it up and have someone step on the brake pedal while you see if the wheels can still be turned by hand. Wheel cylinders could be rusted. Maybe things just need to get unstuck from their winter slumber.
1950 Chevrolet 3100 (Ol' Roy)
Thanks. Just checked and found that there is no braking on the rear wheels. When my wife holds down the brake pedal as hard as she can, I can turn the rear wheels by hand.
