3 members (tclederman, 66flea, 1955 1 Series), 396 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
Is it possible to hook up dash temp and Gen lights and aftermarket gauges simultaneously? I'm rewiring with painless harnesses. Would really like to have both.
1964 Stepside C10
"Well we didn't get all dressed up for nothing." ~ Braveheart
Sir Searchalot
Sir Searchalot
Temp- Possible, two different senders. One gauge style, one light style
Gen- Possible, Depending on gen/alt/gauge used.
I put a T on my oil pressure line so I have the dash light and electric oil pressure gauge.
Lug, is the bell shaped sender for the light guage?
1964 Stepside C10
The big gold bell on the right is the sender for the aftermarket oil pressure gauge. The smaller one on the left is for the dash oil pressure light. Some 1964-66 instrument clusters have an actual gauge, but mine just has a warning light.
Hi,
Yes it's possible to do both. i did on my 63 c10. You will just use the factory wiring harness for the dash idiot lights. For the temperature idiot light, i used the factory harness and connected it to the factory sensor, but used it on top of the intake, because i didn't really care about the light going on from that point. For the aftermarket temp gauge, i used a mechanical gauge and ran it through a factory hole in the firewall and have it coming directly from the engine block. Usually mechanical gauges have the temp sending unit on it. I used a "Stewart Warner" one.
For the gen light, it just uses the factory harness for the light to go on.
For the oil pressure, same thing. I ran a Stewart warner gauge and put the line through the firewall and directly in a port behind the distributor for oil pressure. Reads great too.
So, yes you can do both. I'm assuming you can do electrical gauges, but it's all wiring and maybe more of a voltage sensor, where mechanical gauges give you a true read out.
Hope this helps.
Working on my 64 c10 dash wiring and I need the indicator lenses and the carboard tubes that hold the lenses.
I've been trying a few part sites and none have them for a 64. Does anyone have a lead on where to find them ?
Fuel is the only guage in my dash console rest are the lights.
1964 Stepside C10
Pretty sure the 67-72 dash tubes will work. LINK HERE.
Many different vendors sell them. I restored my 1965 dash and it’s the one without gauges too. Here’s a tip to make the lights a little brighter. Link here.
I talked to classic but ill try a different year. The one I need most is the rectangle ones.
Good idea with the foil !
1964 Stepside C10
Rectangular tubes? Hmmm!
I shop with TruckandCarShop a lot. I’ll look to see what they have available.
TruckandCarShop dot com sells the same tubes as other vendors. Not sure why they only indicate years for 67-72. They should be correct for 64-66 too. Just cardboard tubes with a green or red lens on the end.
