0 members (), 230 guests, and 3 robots.
Topics128,094
Posts1,056,066
Members48,433
#1441181 02/14/2022 6:17 PM
Hopefully the pic shows up…
I need (want) to destroy the one-sided-sticky gasket that’s about 1/4” wide and maybe 3’ long (the part not painted over in the pic). The sheet metal cover under the window crank and inner door handle.
What is the name of the gasket… or what kind of ‘gasket’ would I use in its place?
62 c10 rebuilding it cheap
Family rust bucket 2of2
You should be able to find some sponge rubber sticky sided weatherstripping at your local hardware. Probably similar to what's on there now.
Ok. So just some residential window weatherstripping stuff?
I was kind of hoping for an actual part to order…. But generic weatherstripping sounds less expensive… I will do that.
