Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (VEW, GMCJammer51, 3 invisible), 571 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#1441181 02/14/2022 6:17 PM
Hopefully the pic shows up᠁
I need (want) to destroy the one-sided-sticky gasket that’s about 1/4” wide and maybe 3’ long (the part not painted over in the pic). The sheet metal cover under the window crank and inner door handle.
What is the name of the gasket᠁ or what kind of ‘gasket’ would I use in its place?
62 c10 rebuilding it cheap
Family rust bucket 2of2
You should be able to find some sponge rubber sticky sided weatherstripping at your local hardware. Probably similar to what's on there now.
Ok. So just some residential window weatherstripping stuff?
I was kind of hoping for an actual part to order᠁. But generic weatherstripping sounds less expensive᠁ I will do that.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.160s Queries: 15 (0.157s) Memory: 0.6050 MB (Peak: 0.6560 MB) Data Comp: Zlib Server Time: 2025-09-22 12:44:30 UTC
Valid HTML 5 and Valid CSS
