2 members (baldeagle, Rusty Rod), 74 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1440950 02/12/2022 10:10 PM
Q
Q Offline
So I am trying to replace the drag link and the tie rods on my 1957 AD truck. They are original, bent and rusted. I cannot get the drag link off of the pitman arm. Of course I removed the castle nut and cotter pin. But all the heat and banging will not loosen the little bugger. Any recommendations or special tool needed?
qside #1440955 02/12/2022 10:37 PM
Point of order.... if you have a 1957 you do not have a Advance Design Truck. You have a Taskforce truck. Now that we have that cleared up someone will be along shortly with the answer to your questions.
qside #1440958 02/12/2022 10:39 PM
Special tool called a Pickle Fork, available anywhere tools are sold. You can get the manual version or one that fits your air hammer tool. Also there is a special puller for the pitman arm you might find useful.
qside #1440962 02/12/2022 11:21 PM
If you do not want to use the Pickle Fork which requires hitting with a hammer, you could try this tool which uses pressure.
Harold
Harold
Q
Q Offline
Thank you.
Yes I know I have a TF truck. In my haste and frustration with this stupid joint I lost my mind!
Most chain auto parts stores (O'Reilly's, AutoZone, etc) have rental tools including a pitman arm removal tool. I used on from O'Reilly's last year to pull the Pitman arm on my '52 GMC and replace the leaking seal.
Use the tool to put some pressure on the stud, then hold a BFH on one side of the eye, and smack the other side with another hammer. Should pop right loose. The noise makes the rust molecules that were holding hands let go and cover their ears. wink
