4 members (Swami29, Otto Skorzeny, Gray_Ghost, Youngin' Tut 59), 143 guests, and 1 robot.
Topics128,114
Posts1,056,605
Members48,448
#1440759 02/11/2022 4:32 AM
Can someone explain to me why paint thinner eat's cast aluminum? I bought an old pressurized paint pot and the agitator paddle's have been eaten down to almost nothing.
Are you sure it wasn't water that ate the paddles, and not paint thinner? Aluminum doesn't like alkaline conditions. Maybe someone used some trisodium phosphate solution to clean it out. TSP solution is very caustic (alkaline) with a pH of 12-14.
Big Bolt Forum Moderator
I have a couple of older paint pots I was using to clean brushes and had left some paint thinner in them (not Lacquer thinner, but paint thinner, like mineral spirits.) Mine looks all etched inside as well, come to think of it, so does the one I use for painting and keep lacquer thinner in it.
Mike
Chevies tillId If you notice at swap meets you will see quite a few eaten-up manifolds.
