7 members (JW51, baldeagle, Dennys28, Bill Hanlon, Peggy M, Maybellene, Southerntruck),
62
Mod | | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | How reliable is an engine with a cracked and deformed (out of round for about an inch midway) cylinder that gets professionally sleeved? It's not a stovebolt, but destined to haul one - a 2000 Cat 2136 7.2l diesel in a GMC C8500. Will be gently used for hauling the '52 for longer trips, hopefully for some of the meets below the border if we ever get over Covid stuff. If this needs to move moderators, please do so.
Thanks, Mike | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | This post will probably get zapped pretty quickly- - - -send me a PM. I've been installing sleeves for 50-something years. Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 52 vff Cylinder sleeves if properly captured (so they can't move) will go ahead and wear the engine out. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 52vff In blocks with not much damage would put in a 3/32 sleeve (.093) then bore .030 over. Could get it so you couldn't tell which hole the sleeve was in. Ran those street and in dirt cars never lost one. | | |
