Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, Gdads51, Phak1, 1 invisible), 110 guests, and 4 robots.
Topics128,281
Posts1,058,472
Members48,490
I just pulled the 6 cylinder engine out of my original 1941 GMC Cabover AFKX 352 4X4 van. The plates on the engine and firewall state that the engine is serial number #24820475.
My original GMC AFKX repair manual shows the same (correct) engine and states it could be a 228, 248, 256 or 270, Six cylinder.
Q: Can anyone look it up for me and confirm which engine it is by its serial number? I assuem it is a 270 but do not know for sure.
It also has a water cooler for the oil on front of the water inlet.
Thanks so much for any help :rolleyes: grin :p :confused: :confused: !
Old Coes
Si Lupton
Hartland Vermont
Si, 248ci., According to that No.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Do the first three digits indicate size, or is it just coincidence that his engine is a 248 and the serial starts with 248?
No coincidence.
