4 members (Otto Skorzeny, Nick in Manitou, gswbbc, tclederman), 87 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#1438850 01/26/2022 8:34 AM
I am not sure why my Amp meter always indicates a discharge in the morning while it is near freezing here in the Mojavi desert,then as the truck warms up a bit then it starts charging...
Ol'55 #1438925 01/26/2022 8:10 PM
i dont really have an answer to your question, but some charging systems require a "goose" of the go pedal to hit a higher rpm to get the charging system started. Maybe try a "goose" or 2 and see what happens? Not sure what your driving or what charging setup you have for that matter?? Post some more info and im sure you'll get better responses. Good luck.
#1439048 01/27/2022 5:44 PM
Here lately, starting up my truck in the morning I have a discharge indication on my amp gauge, I'm thinking as cold as it has been here in the Mojave desert it's affecting my reading, now as soon as it warms up say 5 minutes or so she then begins to start charging? The battery is fully charged, so I don't believe that would be the problem.. What do you think there Bolters ?????
ol' 55 #1439049 01/27/2022 5:56 PM
Check the tightness of your fan belt.
ol' 55 #1439105 01/28/2022 2:56 AM
Check the voltage at the battery.
Then pull the throttle knob out a bit to increase the RPM and see if the needle moves to the plus side.
Check the voltage after you pull the knob out a bit and compare it to the reading prior to pulling it out.
This should let you know if it is charging the battery at idle or only at above idle.
ol' 55 #1439130 01/28/2022 9:46 AM
It's just the ol 235, six with a alternator. Like when I leave from work at 3:00 p.m. sun is out and it has warmed up to say about 70 or so it stays over on the charging side whether I am at idle or say around 1000 r.p.m.s..
Ol'55 #1439261 01/29/2022 10:40 AM
Thanks for the info., I got thinking maybe if there was a bunch of crud and stuff all over the coils I would g o ahead and kind of clean it up..
Ol'55 #1439380 01/30/2022 2:56 AM
Thank you for the info. I will keep my eye on it
ol' 55 #1439383 01/30/2022 3:09 AM
Thanks for the info. I will keep my eye on it..
Ol'55 #1439612 01/31/2022 9:16 PM
OL,55 RPM has to get hi enough to prime,certain alt. combinations prime easier than others,once it primes should set at idle and charge...lights brighten-up.
ol' 55 #1439718 02/01/2022 9:22 PM
Sir Searchalot
Sir Searchalot
Check the tightness of your money belt.
glennstowing On my winch truck installed a belt and added sheave so it would charge at idle. Never even dreamed fan could get into it. Fired-up worked fine,happened to see fan cleared by about 1/16 th. so you learn !!
ol' 55 #1439942 02/03/2022 10:50 PM
7
7 Offline
To me it sounds like you need to check and clean the voltage regulator contacts, the regulators are temperature sensitive. The shop manual has a chart of voltage settings based on the temperature of the regulator.
