4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 125 guests, and 1 robot.
Topics128,109
Posts1,056,271
Members48,439
#143890 08/13/2005 6:40 AM
Junior Member
Junior Member
I am wanting to do a SB Chevy engine swap into my 49 1 1/2 ton.Does anyone know if the after market v8 conversion crossmembers for the 1/2 tons will work in a 1 1/2 ton??? How about the trans crossmembers??? I am thinking 283 or 327 with a turbo 400.Mainly because I already have the engines and trans.
#143891 08/13/2005 7:25 AM
You'll need both crossmembers to make the automatic work.
I'd buy generic crossmembers that you cut to fit. That way you'll be able to adjust them to fit your truck.
The turbo 400 uses something like 35 or 40 horsepower just to operate. The additional 44 cubic inches of the 327 would probably be important in this application...
#143892 08/14/2005 9:53 AM
Exactly why I don't like slushboxes.
1954 GMC De Luxe COE
#143893 08/15/2005 5:23 AM
Junior Member
Junior Member
I do still have the original SM420 4spd trans.I could use that.Is there a way to upgrade the old parking brake setup on the back of the trans? Or is that sufficiant.
#143894 08/22/2005 1:17 AM
the old parking brake should be just fine if you reline the pads a keep it adjusted
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#143895 09/09/2005 2:40 AM
I installed a 350 in my 48 2 ton.Had to change rear cross member for v8 bellhousing,used a 55 member and cut it to fit,just cut the old one off at edge of frame.Used 3in. channel for front cross member,put a small bend in it by laying it on two blocks of wood and hit it with a big hammer,make sure the webs are down.Clip the ends to fit in lower frame.I used 1/4in.plate,4in.by7in.for motor mounts,weld to top edge of frame and down to channel.Make sure you mark your holes and drill them before you weld them in.I had to shim the steering gear over 1-1/2in.to clear exhaust,I didn't like the way it steered so I pulled it out and installed a 250 six[same mounts],I like it a lot better.
Lots of luck.
Floyd
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
#143896 09/11/2005 6:36 AM
Junior Member
Junior Member
Thanks for the info!! I am just getting ideas,so when I do start on the truck,I will know what direction to go.But before I start I am going to have to find a title for the truck.And going through the channels is a real pain in Calif.I did it once before,what a joke.
