Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (greenie-reddy, Peggy M, baldeagle), 35 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
#1438767 01/25/2022 9:39 PM
I’m looking for a set of low compression heads for my daily driver. I’m looking for comp ration of right around 8.5 like the stock casting 3927185 heads. It doesn’t matter if aluminum or not. Tried calling all mfg’s but I guess their busy. Any help would be appreciated . Running flat tops and cam ids open. Ps gas is killing me
flattop49 #1438823 01/26/2022 2:27 AM
Crusing in the Passing Lane
9.5 CR is frequently mentioned as suitable for today’s regular fuel.
Ed
flattop49 #1438862 01/26/2022 1:14 PM
7
7 Offline
Should be about a zillion of them available, with flat tops you would want something with a combustion chamber around 74 cc, I would think anything from 72 cc to 76 cc would be fine, stock cast iron Chevy heads are probably the most prolific item around. I built a 383 with flat tops and single valve reliefs, cc'd the heads and did the math and I'm at 9.5 : 1 with 74 cc heads. GM used those from the very early 70's through the early 80's. Call your local machine shop, mine keeps some on hand that they have deemed ok to build. I've got only one set of extra heads but shipping would probably be a killer.
