2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14377 01/19/2003 6:53 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | We do have a fairly low rear end. 4.11 or something like. And the truck, 62, weighs close to 4,000 pounds....
But 10 mpg still seems very poor for a six cylinder engine. Do I need to rebuild/swap carbs?
Thanks in advance.
Then you will know the truth, and the truth will set you free.
- Jesus -
#14378 01/19/2003 6:58 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | That is what I've always expected my 50 3100 with a 1962 235 should get, yet after two tests, I'm getting around 17. Can't say what the heck I'm doing right.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#14379 01/19/2003 7:17 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by cmayna: That is what I've always expected my 50 3100 with a 1962 235 should get, yet after two tests, I'm getting around 17. Can't say what the heck I'm doing right. That sounds much better.... Care to swap engines? P.S. On a serious note, did the '62 engine bolt into your '50?
- Jesus -
#14380 01/19/2003 7:25 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Your rear gears are limiting mileage. You can swap carbs, adjust timing/advance curve, mod the exhaust, and probably get about 3-5 mpg gain (without performance loss); or you can swap the ring and pinion and get about the same results (if not better). | | |
#14381 01/19/2003 10:59 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I got 12 MPG with a 235 and a 4.57 rear end. 10 MPG with a 4.11 is low. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#14382 01/20/2003 12:50 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Are you sure that your speedometer is accurate ?
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#14383 01/20/2003 1:05 AM | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | Are you sure your rear axle ratio is a 4.11? My 62 is a 3.90 and these were alot more common. Anyways i have a rebuilt 235 about 3500 miles on it now and i am getting 24 miles/per/gallon  I just put in a S10 5 speed tranny and i figure i will be getting close to 30 miles/per/gallon now!!  my tires are 225/70/15 | | |
#14384 01/20/2003 4:01 AM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | JunkYardFrog, The 62 engine came out of my '53 after my front Oak leveled it. I bought the '50, put both vehicles on stands and changed complete drivelines (engines, trannies, drivelines). So actually the rear end is not a '50 but a '53 but still 4:11's.
Craig
#14385 01/20/2003 5:27 AM | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | I also get @ 10mpg as well. My casting no. suggests that this 235 was birthed between 58-60'. The carb is the ol single Rockchester. I've got the 3 on a tree and don't exceed going slow all the time. I'm hoping that someone chimes in who understands what the hay is going on ans can lay it out in Asst. Wrench Fetcher terms. I also have a gasket leak on the fuel pump, but not enough to make a difference. | | |
#14386 01/20/2003 6:18 AM | Joined: Apr 2002 Posts: 23 Member | | Member Joined: Apr 2002 Posts: 23 | my friggin f*rd with its 302 and overdrive are getting 10 mpg. and my pickup has something like 3.23's in the rear. hopefully ill get alot more mileage out of it when it gets warmer.
but yea, my friend drives a 93 f*rd with a modded 351 and 4.10s, and during the spring he can sometimes pull off 17 mpg.
Its odd if youre getting that low of mileage with such a small engine
Drew
55 2 dr 210- after college project 56 2 dr 210- after '55 project "D'oh"
#14387 01/20/2003 10:05 AM | | Anonymous Unregistered | | Anonymous Unregistered | What are you guys crying about?! I drive my '54 3800 panel to work which is 50 to 60 miles round trip and endup putting 11 to 15 gal. of gas back in the tank to fill itup (18 gal tank). Oh yeah, I was running 235x16s and switched back to the orignal size tire,7.50 x 17's to try and get the ratio lower(better gas milage?) so I could go faster than 40? with this 5.14 rear end. Tony'n Weatherford, Texas that is.  | | |
#14388 01/20/2003 12:08 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | You guys driving easy and getting 10 MPG should look at your carbs. Old Rochester B's have been know to the power valve jet open at low speeds.It usually won't have black smoke rolling out, but rich enough to kill the fuel mileage.Our 45 2 ton with a 235 gets around 11-12 mpg, and it heavier and lower geared than a pick up. | | |
#14389 01/20/2003 5:36 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by Tony: You guys driving easy and getting 10 MPG should look at your carbs. Old Rochester B's have been know to the power valve jet open at low speeds.It usually won't have black smoke rolling out, but rich enough to kill the fuel mileage.Our 45 2 ton with a 235 gets around 11-12 mpg, and it heavier and lower geared than a pick up. Thanks Tony, That sounds like a good suggestion.
- Jesus -
#14390 01/20/2003 5:39 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by PJ_STYLES: I just put in a S10 5 speed tranny and i figure i will be getting close to 30 miles/per/gallon now!! Very interesting.... I never hear of that before, but I'm new to this. How'd you do that? Is there some kind of adaptor required to bolt up that tranny?
- Jesus -
#14391 01/20/2003 6:33 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Tailgate up or down? This can help, my '68 C-10 used to get 3-5 better MPG with the tailgate down.
Beyond that, I'd start looking at the carb and ignition system. Might be running way rich.
Everything else in good shape and adusted? Coil, condenser, points gap, spark plug gap, rotor, and wires...
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#14392 01/20/2003 8:15 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | JYF, Have you checked the air in your tires? Must be running with all four flat-LOL. You may consider putting in a three speed w/o (with overdrive).
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#14394 01/21/2003 12:33 AM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | hmmm Thanks. Very interesting.... But over my capabilities at this time. It sounds good though!
- Jesus -
#14395 01/21/2003 12:37 AM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by Oly: JYF, Have you checked the air in your tires? Must be running with all four flat-LOL. You may consider putting in a three speed w/o (with overdrive). hahaha Thanks a lot!!! Don't worry. They're only flat on one side. I'm gonna start with the carb, but your mention of overdrive has me interested. The poor thing really has to work to stay up with traffic on the freeway. Was there a factory overdrive available? I'm not up to the amount of work required to put in a 5-speed.
- Jesus -
#14396 01/21/2003 12:39 AM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by boyoconnor: Tailgate up or down? This can help, my '68 C-10 used to get 3-5 better MPG with the tailgate down.
-Boyo Good point! I haven't checked it both ways. I'm surprised it could make that much difference. I will have to check the mileage again. It seems to be better lately, but right now my son has the tailgate removed to sand off the rust. That could be the key. Thanks for the tip!
- Jesus -
#14397 01/21/2003 1:25 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My '50 with a 216 in it and 4.11 gears got 19mpg, even with two engines in the back driving on the freeway at 55 mph, making GVW about 4600. It really sounds like you need to set your carb and check your vacuum advance, timing, and point gap too. I found that the dwell angle and timing setting made a huge differance in how well my truck ran. If your vacuum or mechanical advance is broken you will get terrible gas milage. Ditto on the power valve. Ditto on the timing being wrong. I like to run a slightly wider than spec point gap for a hotter spark. It just requires re-setting a bit more often. I have a dual point distributor that the 261 is going to get. Also check for fuel leakage, that will really fool you!
#14398 01/23/2003 4:37 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Woohoo! 12 mpg!!! Oly was right about putting air in the tires.
- Jesus -
#14399 01/23/2003 4:39 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by boyoconnor: Tailgate up or down? This can help, my '68 C-10 used to get 3-5 better MPG with the tailgate down.
-Boyo Hey Boyo, You nailed that one. Got two more mpg with the tailgate down. Up from 10 to 12. That's a 20% improvement. I'll hafta dig into the carb and ignition situation soon. Thanks for all the ideas.
- Jesus -
#14400 01/23/2003 5:42 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Frog said: The poor thing really has to work to stay up with traffic on the freeway. This is part of your problem right there. If your traffic is anything like around here then they are going 65mph plus. To make one of these old trucks go 65mph your rpm's become astronomical and your mileage space shuttle like.
54 3100 with 235 62 flatbed dump C60 with 261
#14401 01/23/2003 7:55 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Frog, When I was running my '54 Chevy 3/4 ton, with 4.57 rear, and 235 w/ Rochester B, I was averaging about 12 mpg. If I drove it faster than 50 mph, the mileage plummeted! My '72 C-10 w/ 250/Rochester B and 3.73 (?)rear, seems to be doing about 16 mpg highway. Again, if I drive faster then 60 mph, then I can watch the gas gauge visibly fall towards empty (at 60 mph, the engine's roughly turning 3,000 rpm). This has been my experience... with the '54, I always used to scratch my head when I'd look at the serial plate on the door pillar which was silver lettering on a blue background: at the top of the plate it said "Chevrolet- for economical transportation"....being a poor kid in high school at the time, 12 mpg didn't sound particularly economical to me !
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#14402 01/24/2003 4:56 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by Frank54: Frog,
hmmm Okay. You convinced me. I'm gonna try another test and keep the speed between 50 and 55. But in advance I'm asking for special prayers. I'll be going 20 to 30 mph slower than some of the traffic on our freeways!
- Jesus -
#14403 01/24/2003 6:29 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | There is nothing like blasting at high rpm in the slow lane and then getting passed by a grey haired lady in a Buick.
#14404 01/24/2003 7:07 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | How 'bout doin' 65mph in the "slow lane", (trying to keep out of the way of traffic, even though the posted limit is 55 mph), on a cold snowy morning w/ a dusting of snow on the highway (just enough to make it slick), and you still have people blasting by you doing 75, 80, plus...in their rice-rockets or uber-SUVs, yappin' on the cel phone, puttin on the make-up, etc, while you're there in the "slow" lane listening to that long-stroke bolt scream, wondering how much more it'll put up with....
And that's in a '72 C-10 !!!
Better-off taking "the milk route" (& stopping for ice cream along the way!)
(sigh)
Gotta keep those revs down to get any kind of respectible fuel "economy"...
