| | | Forums66 Topics128,003 Posts1,055,243 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | I’m looking for a set of low compression heads for my daily driver. I’m looking for comp ration of right around 8.5 like the stock casting 3927185 heads. It doesn’t matter if aluminum or not. Tried calling all mfg’s but I guess their busy. Any help would be appreciated . Running flat tops and cam ids open. Ps gas is killing me | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 9.5 CR is frequently mentioned as suitable for today’s regular fuel.
Ed
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Should be about a zillion of them available, with flat tops you would want something with a combustion chamber around 74 cc, I would think anything from 72 cc to 76 cc would be fine, stock cast iron Chevy heads are probably the most prolific item around. I built a 383 with flat tops and single valve reliefs, cc'd the heads and did the math and I'm at 9.5 : 1 with 74 cc heads. GM used those from the very early 70's through the early 80's. Call your local machine shop, mine keeps some on hand that they have deemed ok to build. I've got only one set of extra heads but shipping would probably be a killer.
