Topics128,127
Posts1,056,675
Members48,450
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Rebuilding my steering box on my 1949 3600. Went to replace the lower worm shaft roller bearing, but cant figure ouy how to get it off. The books dont mention the piece that is holding the bearing on. Bearing looks ok, but i have a replacement i was going to put on if i am able.
1949 chevy 3600 First attempt at restoration
Curmudgeon
Curmudgeon
Bearing Collar?
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
Curmudgeon
Curmudgeon
