7 members (52Carl, 2-Ton, 39Master85, Peggy M, ‘37ChevyPU, Uncles51, 1 invisible), 107 guests, and 3 robots.
Topics128,140
Posts1,056,466
Members48,441
Rebuilding my steering box on my 1949 3600. Went to replace the lower worm shaft roller bearing, but cant figure ouy how to get it off. The books dont mention the piece that is holding the bearing on. Bearing looks ok, but i have a replacement i was going to put on if i am able.
1949 chevy 3600
First attempt at restoration
Curmudgeon
Curmudgeon
Bearing Collar?
Thank you!
1949 chevy 3600
Curmudgeon
Curmudgeon
X
X Offline
SteveJ,
Not sure if you're done yet, but I documented my steering box rebuild in video form. Here's a link to the post I made with all the videos:
https://www.stovebolt.com/ubbthread...d-and-adjustment-videos.html#Post1397378
Good luck!
1949 GMC FC253 - 1 Ton Dually
1966 Buick Wildcat Convertible
