| | | Forums66 Topics128,180 Posts1,057,154 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 42 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 42 | I have just purchased a kit to rebuild the Delco master cylinder on my 1940 pickup. When I set out the parts, there is an extra rubber piston/washer that was not in the pieces I pulled out. can someone please point me in the direction of an exploded diagram or photo of the assembly order of the pistons, pushrod, check valve, spring, etc. Many thanks in anticipation, Riggles, Australia. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The round rubber washer goes on the big nut on the rear end of the MC. It is the seat for the check valve on the end of the spring. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | | | | | | Joined: Sep 2018 Posts: 42 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 42 | Men, thanks very much for the info. George, I don't know how I didn't see the washer in the end, must have had an eye closed! I have now got it all together & will start & put it all together over the next couple of days. I have printed off the diagram of the master cylinder, so my sons will have something to help them in the years to come. I am making a new sound deadening layer to fit under the floor mat, which should also reduce some heat coming up from underneath. Once again, thanks for the help. The help & advice I have received over the last few years has been great, and I tell friends what a great forum this is. | | | | | Joined: Sep 2018 Posts: 42 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 42 | George, one thing I don't see on the diagram of the master cylinder assembly (as in the links sent by joe apple), is the shim washer which was between the piston cup & the end of the piston with the small radial holes. Is it supposed to be there? There was one fitted when I pulled it all apart, and there was a new one in the kit. Is it an omission on the diagram? Thanks again, Riggles | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its been a long time but it seams like that is part of the piston. You put it in there I suppose. There are 2 small bypass holes in the bottom of the reservoir. Make sure they are open. One is very small. You may need to run a tag wire through it.
George
Last edited by Wrenchbender Ret.; 01/28/2022 4:55 PM. Reason: Reservoir instead of cyl.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2018 Posts: 42 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 42 | It's all done and once again, the little Red truck stops as good as some of the late models. The power booster under the floor really helps. Thanks again men. | | |
