4 members (BarryP, Bucker, Peggy M, LAJones48), 131 guests, and 0 robots.
Topics128,162
Posts1,056,917
Members48,458
#1437746 01/18/2022 4:23 PM
Surely someone will know what I'm looking for, the proper name of this tool. It is a socket that looks like a screw driver ( flat blade), used to take apart tie rod ends. I need to purchase one but don't know what it's called.
Thanks.
Tommy
59 apache 1/2t
261 short stepside
Crusty Old Sarge
Crusty Old Sarge
I have always referred to them as a spade bit, that may not be correct but here is a link.
https://www.googleadservices.com/pa...1AhUEheAKHWdZDsoQ9aACegQIARBd&adurl=
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
They're called drag link sockets. There's usually a bunch of them on Ebay for reasonable prices. Get one that fits the slot exactly, or grind a bigger one for a close fit.
Edit: I just found at least 50 of them in about 5 minutes.
Thanks Guys.
Tommy
59 apache 1/2t
261 short stepside
Tommy, I'm in the middle of a kingpin/tierod end project. To remove the threaded ends of the tie rod/drag link I didn't invent a tool but found something that worked great.
Laying on the workbench next to the vice, a few scrap pieces of 1/8th flat stock was just waiting for a job. After cleaning the tie rod end slots one of the small pieces of scrap was an exact fit, it fit the full length and depth of the screwdriver slot. Add a 10" crescent to the mix and it was an easy job to remove the ends.
RonR
RonR
1970 340 Duster
1964 CJ5
I tried that, but the plug was so tight it twisted the flat stock. Ordered a drag link socket to complete the job. I suppose I could have cut the tie-rod ends off, as I replaced balls and tie rod ends with the modern type.
RonR,
Back years ago when I did my 59 Apache, I did exactly like you said, It worked great. Now I'm working on a 1936 Chevy ( 5 window coupe) I know it's not a truck, But it's not working. I figured I better get the right tool before I get to involved.
Tommy
59 apache 1/2t
261 short stepside
Weld a very short piece of flat stock to a big nut and put a socket on the nut...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
