| | | Forums66 Topics128,134 Posts1,056,736 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Surely someone will know what I'm looking for, the proper name of this tool. It is a socket that looks like a screw driver ( flat blade), used to take apart tie rod ends. I need to purchase one but don't know what it's called.
Thanks.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | They're called drag link sockets. There's usually a bunch of them on Ebay for reasonable prices. Get one that fits the slot exactly, or grind a bigger one for a close fit.
Edit: I just found at least 50 of them in about 5 minutes. Jerry
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Tommy, I'm in the middle of a kingpin/tierod end project. To remove the threaded ends of the tie rod/drag link I didn't invent a tool but found something that worked great.
Laying on the workbench next to the vice, a few scrap pieces of 1/8th flat stock was just waiting for a job. After cleaning the tie rod end slots one of the small pieces of scrap was an exact fit, it fit the full length and depth of the screwdriver slot. Add a 10" crescent to the mix and it was an easy job to remove the ends.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | I tried that, but the plug was so tight it twisted the flat stock. Ordered a drag link socket to complete the job. I suppose I could have cut the tie-rod ends off, as I replaced balls and tie rod ends with the modern type.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | RonR, Back years ago when I did my 59 Apache, I did exactly like you said, It worked great. Now I'm working on a 1936 Chevy ( 5 window coupe) I know it's not a truck, But it's not working. I figured I better get the right tool before I get to involved.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | Weld a very short piece of flat stock to a big nut and put a socket on the nut... Mike B  | | |
