2 members (jay d, Gdads51), 75 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
An interesting video of a 261 500HP engine build. Looks to be dated 10/2021.
The skill and knowledge to pull this off is impressive. The price tag is not revealed.
I think that this is the third or 4th. time that build has been featured in a thread. Other than the block and the crankshaft, that thing resembles a 261 about as much as a sirloin steak resembles a can of Spam. I'm working on something similar, except it's going to have close to 300 cubic inches, and it actually uses stock 261 pistons. No, I don't use a turbo, and the HP is probably closer to 150-175 than 500, but the engine will actually be useful for something other than bragging.
Hello, Jerry,
Sorry about this question that is minimally related to this thread.
What would be the displacement of a 1960 261 USA truck engine that is 060 over-bored (with 1960 261 standard cam shaft)?
Tim
Lemme grab the calculator- - - -back shortly!
269.2 cubic inches. 60 over gets you about 8 cubic inches extra.
Price? 4 times as much as the same power from a Barra or 2JZ
Cubic inch displacement (CID) formula:
Bore divided by two- - - - -60 over would be 3.810"- - - -half of that is 1.905
Bore radius squared- - - -1.905 X 1.905 = 3.629
3.629 X Pi (3.14) = 11.395 multiplied by the stroke (3.9375) = 44.87 cubic inches- - - -displacement of one cylinder.
44.87 X 6 = 269.21 cubic inches.
Thanks, Jerry
I rebuilt that engine in 1970 (my second and last USA engine rebuild).
It is still in my 1954 3106 (1/2 ton) Suburban.
After I put in the 3.55 R&P gears (and all new bearings/seals/etc in the torque-tube and rear axels), and after I went through a break-in procedure, I took my young professional mechanic/painter-friend for a ride on a long straight rural road. He almost wet his pants when I easily reached 93 mph. That was over 25+ years ago.
That USA 261 is a great engine. The only thing that I have changed is the carburetor.
Think of what it could do with an extra 30 cubic inches and a lot more torque. The one I've got on the drawing board is going to have a 4 3/8" stroke instead of 3 15/16". There are a few more sneaky tricks up my sleeve as well!
