13 members (Otto Skorzeny, gswbbc, 68ironhead, baldeagle, Ol'55, 3B, Shardean, Cheapskate1229, panic, JW51, Jamesrsimone, Joe H, 1 invisible), 109 guests, and 2 robots.
Topics128,039
Posts1,055,473
Members48,424
#1437451 01/15/2022 11:44 PM
7
7 Offline
Will the stock air filter from a 283 sbc fit a 250 straight?
I check RockAuto.com. I usually search for the part I want and see if part numbers match for both applications. RockAuto is usually very accurate about parts.
I searched for 230ci, 250ci and 283ci.
Looks like the 230 matches the 250 (Wix).
Looks like the 283 isn’t the same.
7
7 Offline
Ok thanks
Lugnutz #1437560 01/17/2022 1:20 AM
I have had mixed results on that. Most of the parts they have listed will fit *some application* of the vehicle, but a lot of the time it is not the stock or normal configuration.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
7
7 Offline
Are you looking for a filter element or housing?, oil bath? dry paper?
7
7 Offline
i was talking about the housing dry paper. The one I have will work on the 250. It clears the valve cover. I think it is a little bigger than the 250 one
