| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 98 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 98 | I recently installed a 350 engine with a turbo 350 transmission in a 1956 short bed pick up. We had to cut the old engine/trans mount out to for the install to fit. My question has anyone performed this modification? Was it required to box that part of the frame to retain any frame support. We used the bolt in engine and transmission mounts.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | In my ‘55.2, I am lowering the crossmember between engine and trans. to get clearance for Cummins 5.9, plate the bottom of existing, use that plate for top of lowered crossmember, cut off above plate, extend sides down 2”, add plate on bottom.
Ed
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Since that crossmember also stabilizes the frame rails at the rear spring mounts, unless you're also butchering up the frame with an IFS, the crossmember needs to stay put. Fabricate a dropped section like Ed has described to avoid frame flexing and squirrely handling. Jerry
| | | | | Joined: Feb 2021 Posts: 98 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 98 | Thanks for the inputs. We thought it would need to be retained and modified. I will post some picks after we get it welded up. Thanks guys. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Plan ahead- - - -a little extra clearance comes in handy when the transmission needs to be removed for the inevitable rebuild- - -unless you're planning to make that the next owner's problem. Jerry
