0 members (), 91 guests, and 1 robot.
Topics128,055
Posts1,055,782
#143592 07/25/2005 10:44 PM
any advice for smoother up shifts on the vacuum rear in the lower gears?
i can split shift fine from 2nd to 4th and from fourth to 2nd. the up shifts in 2nd and third alone are fast and jerky which rock the whole drive train. eek
when split shifting or just up shifting in 4th are smooth as can be. grin i want to be able to do that in the lower gears with all the hills i contend with.
#143593 07/26/2005 8:44 PM
H Online: Content
Ok, I think I understand, but if not, sorry! You're going from 2nd. low range to 2nd. high, right? Here's how I'd do it: With power applied, move the splitter knob to the "high" position, the quickly ease off the gas and tap the clutch. This allows the planetary unit to shift in a no-load situation, and it's like making any other gear shift. Downshifting is accomplished the same way, but it's usually not necessary to declutch, just pre-select low range, and quickly back off and re-apply power. By making the shift selection with the load on, the diaphragm has time to preload the shift shaft and make a quick change to the other ratio. If I'm not understanding the problem, try to explain it a little more completely.
#143594 07/27/2005 1:26 AM
Jerry, I think you hit it perfectly. This is as explained in my old Chevrolet owners manual.
#143595 07/27/2005 1:44 AM
thanks, ill have to try that. when shifting up i was only getting off the gas and back on without tapping the clutch.
sometimes 3rd went smooth and 4th always were smooth that way
#143596 07/30/2005 7:55 PM
could depend on your rpm as well some transmissions and rears just seem to have a sweet spot. In the 80's I was driving cummins power with roadranger transmissions. Some folks like to wind them out to 2100 rpm every gear I found shifting at 1900 to be smoother. So experiment with your rpm a little also how fast you jump back on the throttle is an issue since the rpms have to drop the higher ratio rear. Now we shift at 1400 rpm oldtimers would be rolling in their graves if they could see it.
#143597 07/31/2005 7:11 PM
thanks for the advise. smooth shifts with just a touch of the clutch. one guy heard me going through the gears and asked me if a had a 10 speed in that thing and i said nope just an 8. he got this puzzled look on his face :confused: and i just smiled and kept going. grin
#143598 08/01/2005 3:48 AM
yes you are correct just tap the clutch enough to release the pressure no need to go all the way to the floor . timing is the key, developing an ear for proper rpm for the shifts.
#143599 08/01/2005 10:00 AM
V
V Offline
you might try installing a vacuum reservoir from a cadillac in the line.
