0 members (),
74
0
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,048
Posts1,055,540
Members48,425
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
I have a 1946 Chevy 1/2 ton that came without a bottom bench seat. I have a chance to pick up a real nice mid 60s C-10 bench. Can I convert the bottom to fit the 46?
Anything is possible. These 41-46/7 cabs are much tighter than the later cabs. eBay lists original seats and I’m sure if you posted a Wanted ad here someone can set you up with the correct 41-46 seat
Plywood and foam? Sculpt it how you want?
That's how I did my Suburban seats.
Nice. Did you use 5" foam? Just lay out a pattern from the bottom and go from there? I like it.
I started with 5", found it too thick. Went with 4". Made the 3/4" base panel, made the foam slightly larger to soften the plywood edges.
