1 members (MikeE), 70 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#1435648 01/02/2022 1:45 AM
I have a 1946 Chevy 1/2 ton that came without a bottom bench seat. I have a chance to pick up a real nice mid 60s C-10 bench. Can I convert the bottom to fit the 46?
Anything is possible. These 41-46/7 cabs are much tighter than the later cabs. eBay lists original seats and I’m sure if you posted a Wanted ad here someone can set you up with the correct 41-46 seat
1946 GMC Project
"Back-in-the-day Restore"
Plywood and foam? Sculpt it how you want?
That's how I did my Suburban seats.
Nice. Did you use 5" foam? Just lay out a pattern from the bottom and go from there? I like it.
I started with 5", found it too thick. Went with 4". Made the 3/4" base panel, made the foam slightly larger to soften the plywood edges.
Moderated by  ndkid275, Phak1
