4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#1435015 12/29/2021 1:36 AM
Pulled the clutch and found it to have oil on it. Appears to becoming from the rear main. 216 engine can the main be pulled with out taking the oil pan off? Engine is out of truck.
No ! You need to pull the pan
Thank you. I should do what I don't want to do as that is what usually happens.
The permanent fix is to machine the back of the block and the rear main bearing cap for a full circle lip seal like the late model Chevy V8's run, but that requires a complete teardown of the engine to a bare block, and a machinist willing to do the job. The seal is 3 7/8" inside diameter, 4 3/4" outside diameter, and 3/8" thick. I have a home-brewed fixture for my cylinder boring tool to do that job- - - -otherwise it takes a Bridgeport milling machine with a right-angle cutter adapter and about half a day of setup work.
5 Online: Content
Hey Jerry. With a 216 which uses shims to set up the main bearings, would you have to set up the crank shaft oil clearance with the shims before you machined the back of the block and the main cap for the one piece seal?
Not necessarily, although it would probably be a good idea. The seal lip itself will accomodate a diameter difference of around .015" according to the specifications, but the metal ring it's mounted into likes round holes. I think I'd set up the oil clearances first, then remove the crankshaft and reinstall the rear main cap including the right shim pack before boring the counterbore for the seal. My boring bar centers itself in the rear main bearing bore to make the seal counterbore concentric with the crankshaft. I made a 1" thick flat steel plate fixture that bolts onto the back of the block using the bell housing bolt holes, to secure the boring bar.
