7 members (BC59, David Bush, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
83
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 48 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 48 | I’m located in the Anderson, Tx area. I’m northwest of Houston about 13 miles east of College Station. I’m enjoying the web site. Lots of good folks and help. If any of the guy want meet in east Texas let me know.
1946 1/2 ton
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Hopefully we can do a cruise and get together somewhere in between Houston and San Antonio for lunch.
Chris | | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | There is a really good mexican food restaurant in Columbus, it's about half way between HOU and SAT. It's on the main street a block south of I-10. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | We might need to consider a cruise out there! | | | | | Joined: Sep 2018 Posts: 48 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 48 | I’m getting the engine replaced in my 46. When it’s done I will need to make sure all is ok and will be ready to try for the cruise.
1946 1/2 ton
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Great! What engine are you pulling, and what are you putting in?
Chris | | | | | Joined: Sep 2018 Posts: 48 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 48 | The engine that is coming out is a worn out Chevy 350. A guy had purchased a GM Vortex 350, had a Comp cam and bee hive springs and decided he needed the money. It is a new 4 bolt main block. He had a new Edelbrock Endurance Shine manifold. I just got my Mustang ll front end on the truck with 11” Chevy disc on the front. I’m trying to make a driver.
1946 1/2 ton
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I drove mine to work 3-4 times a week with my 216 in it and a straight axle. | | |
