| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 34 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 34 | Someone else must have run into this problem and came up with a created fix. I bought a a window channel kit from The Filling Station. Old parts removal went great until it came to the small rubber scrapers. It says that the pieces must be slid into metal retainer channel. HOW DO YOU CLEAN THE CHANNEL. The top part was ok but I can not get to the groove on the bottom. Is there a special tool that I need? If I have to use heat how much before I blister the paint. Have spent two days on this and I don't want to skip over it. Old guy is getting very fustrzted. Thank you.
| | | | | Joined: Aug 2009 Posts: 193 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 193 | The rubber kit I purchased forewarned me that the channel would need to be spread open to remove the old rubber and insert the new. I did this yesterday with good results. I used a small tip screwdriver, paper towel and WD40. | | | | | Joined: Sep 2021 Posts: 34 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 34 | Thank you. As soon as they ok me to go into the garage.i will try it. I just bought a fine point grout scraper. Plan to heat the point and try that. Will post the results. | | | | | Joined: Sep 2021 Posts: 34 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 34 | 46 Texco. Your way worked far better than mine. Thank you for the help. Now on to the next problem. | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | Any pictures as to how it turned out?
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
