8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible), 103 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
Someone else must have run into this problem and came up with a created fix. I bought a a window channel kit from The Filling Station. Old parts removal went great until it came to the small rubber scrapers. It says that the pieces must be slid into metal retainer channel. HOW DO YOU CLEAN THE CHANNEL. The top part was ok but I can not get to the groove on the bottom. Is there a special tool that I need? If I have to use heat how much before I blister the paint. Have spent two days on this and I don't want to skip over it.
Old guy is getting very fustrzted.
Thank you.
The rubber kit I purchased forewarned me that the channel would need to be spread open to remove the old rubber and insert the new. I did this yesterday with good results. I used a small tip screwdriver, paper towel and WD40.
1946 Chevy 1/2-Ton
Thank you. As soon as they ok me to go into the garage.i will try it. I just bought a fine point grout scraper. Plan to heat the point and try that. Will post the results.
46 Texco. Your way worked far better than mine. Thank you for the help. Now on to the next problem.
Any pictures as to how it turned out?
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
Moderated by  ndkid275, Phak1
