4 members (UtahYork, Otto Skorzeny, Gdads51, Bicounty), 145 guests, and 7 robots.
Topics128,089
Posts1,056,130
Members48,435
#1434578 12/23/2021 9:21 PM
Had my truck across the scales recently... The weight of it unloaded, with all fluids, driver (me), and flatbed with a front bulkhead was a grand total of 6400 lbs.
I'm more impressed now that it can run 60 mph, but the 5-6mpg makes more sense.
Big Bolt Forum Moderator
I guess I should not feel too bad about getting ~8 in my 58 2 ton, it weighs 9,000 empty. What engine are you running in yours?
Mike
My '57 10500 Fire Engine would run 65 mph at 7 mpg with the stock 322 V8 and a 5+2 trans/rear. It weighed 14,400 pounds with no water in the tank...I put 30k miles on it driving to shows and in parades...fun memories!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
69Cuda #1434687 12/25/2021 4:40 AM
69 cuda My 51 6400 pickup with 8.25x20 rubber scales 53 hundred gets 8or 9 MPG on straight propane,HEI, had a noise I fixed with .002 under bearings turned into it in the truck. Now it keeps the 30 pound gage pegged summer and winter,best pickup iv'e had drive it daily.
69Cuda #1434793 12/26/2021 7:51 PM
235, 4 speed, single speed rear end. That’s mostly highway, WOT… But I also had a rear brake a bit snug. If it matters, my intake heat riser valve is/was stuck on. I just unstuck it yesterday, and loosened the brake.
That valve though probably won’t work right. The counter weight broke off so I had to drill a new hole for the pin. Beating on the shaft mushroomed the end so that resulted in some adjustments to get the weigh back on - so it’s not tight on the shaft anymore. With it now free the weight doesn’t pull the valve shut as the spring warms up and relaxes.
Oh well for now.
