7 members (TexasA&M48Truck, Bill Hanlon, Shade Baby, Nhluvstruck, Brian Moore, Wally / Montana, 1 invisible),
227
Mod | | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | Had my truck across the scales recently... The weight of it unloaded, with all fluids, driver (me), and flatbed with a front bulkhead was a grand total of 6400 lbs.
I'm more impressed now that it can run 60 mph, but the 5-6mpg makes more sense. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I guess I should not feel too bad about getting ~8 in my 58 2 ton, it weighs 9,000 empty. What engine are you running in yours? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | My '57 10500 Fire Engine would run 65 mph at 7 mpg with the stock 322 V8 and a 5+2 trans/rear. It weighed 14,400 pounds with no water in the tank...I put 30k miles on it driving to shows and in parades...fun memories! Mike B  | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 69 cuda My 51 6400 pickup with 8.25x20 rubber scales 53 hundred gets 8or 9 MPG on straight propane,HEI, had a noise I fixed with .002 under bearings turned into it in the truck. Now it keeps the 30 pound gage pegged summer and winter,best pickup iv'e had drive it daily. | | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | I guess I should not feel too bad about getting ~8 in my 58 2 ton, it weighs 9,000 empty. What engine are you running in yours? 235, 4 speed, single speed rear end. That’s mostly highway, WOT… But I also had a rear brake a bit snug. If it matters, my intake heat riser valve is/was stuck on. I just unstuck it yesterday, and loosened the brake. That valve though probably won’t work right. The counter weight broke off so I had to drill a new hole for the pin. Beating on the shaft mushroomed the end so that resulted in some adjustments to get the weigh back on - so it’s not tight on the shaft anymore. With it now free the weight doesn’t pull the valve shut as the spring warms up and relaxes. Oh well for now.
