2 members (Otto Skorzeny, 1 invisible), 136 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
Hello,
I’m replacing the wiring harness in my 49 3600 and have found a discrepancy in the Jim Carter directions and the internet.
The instructions say to connect to the amp meter + terminal on the drivers side of the gauge.
The internet says the passenger side is the + terminal.
If you are looking at the back of the gauge, I have 2 posts on the amp meter. I’ll call them 9 and 11 o’clock. 9 is the back side of the C end of the gauge and 11 is the D end. My original harness has 2 wires on the 11 o’clock post and 1 on the 9 o’clock.
What is correct?
Pat
1940’s tech was great in the 40’s
I'm going to attach two files , one pdf , showing the gage cluster and one is a wiring diagram for a 1949 Chevy Truck. Both were colorized by another stovebolt member whose name I have forgotten. On the wiring diagram ignore the turn signal wiring if not applicable. Hopefully these will help with your question. Short answer is the minus (- ) is at 11 o'clock and the plus (+) is at 9 o'clock. I'm making an assumption that the "new " wiring harness is color coded to nearly match the original. I'm not an expert, but PM me if you have specific questions and I'll try to help.
Ron - - Dusty53
1954 Chevy 3604
Curmudgeon
Curmudgeon
At the bottom:
Drawn by Scott Voss (bztguy on www.stovebolt.com)
Thanks!
It looks like a typo on the directions.
Wires 2 & 23 are in question. I’ll reverse their locations.
[img]https://www.stovebolt.com/ubbthread...4A93C16-32AD-4594-919F-94AAC8F803B0.jpeg[/img]
Pat
Originally Posted by buoymaker
At the bottom:
buoymaker - Thanks for pointing that out, Scott did a great job. I saved his file for future reference and use and was able to send it forward. Thanks again !
Ron - - Dusty53
1954 Chevy 3604
I'm glad my drawings helped. I submitted them for the tech tip section when I first posted them but they never showed up there....
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
