Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 525 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
V
V Offline
Hey guys I want to run the stock 16" wheels and need to know what is the modern equivalent of a 6.50 x 16 tire? I want to run a radial whitewall with hubcaps, but I'd like them to be a bit wider than the stock tires were. I'm not going to be "performance driving" my suburban, but it will have a modern LS & 4L60E driveline under it. For braking safety, I'd like to have a wider contact patch for emergencies where I might need to slam on the new power brakes (discs and drums).
I'd love to run a 205 or 215 75R16 if it will fit. I want a soft ride, but not a lot of body roll. Passenger tires typically allow for more body roll than a truck tire. Does such an animal exist that will fit a stock 16" wheel? I think a factory 16" is only 4.5" wide.
Advance Design Newbie.
Curmudgeon
Curmudgeon
Personal taste gets it the way of recommending a tire.
The best thing to do is, do your own research.
Determine what rim you have.
Select which tire that will safely fit.
Search the Internet for a picture of the tire & rim combination and see if it is to your liking.
Old tire conversion table:
https://www.turbinecar.com/tires.htm
Attached is the tire and wheel page of the 1951 from the gmheritage website:
https://www.gmheritagecenter.com/do...hevrolet-Trucks/1951-Chevrolet-Truck.pdf
Consider that your rims were designed in an era when radial tires did not exist.
About 1969 started radials in the USA then 1982 cars and some trucks were standardized with radials.
Also modern rims do not have the clips needed to hold original hubcaps.
The first thing to do is figure out how wide your rims are. Depending on the year, they were available in 4", 4.5", and 5" wide.
That will be your biggest limiting factor in what can be safely installed. Once you know that, you can look to see what tires you like are available in tthat size.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I like the looks of the 215/75/R16 tires on an AD truck. Fills the fender openings about right and the face is a bit wider than the factory 650/16's.
[img]https://i.postimg.cc/0M44YXRp/evan-truck-007.jpg[/img]
[img]https://i.postimg.cc/Zvh8z66G/evan-truck-006.jpg[/img]
Evan
V
V Offline
4.5" Width according to the data you provided! THANK YOU! This helps a lot!
V
V Offline
Great point. I didn't know the wheel widths changed over the years. I'm definitely looking for a set of 5 inch wide 16" diameter wheels. I gotta run my shiny new hubcaps! grin
V
V Offline
Me too! It looks so pertectly to scale on our trucks!
If nothing else, I guess I can fork out the big bucks and have some custom made as a last resort.
Comparative measurements for every size tire ever invented at www.tiresize.com
1951 Chevy Panel Truck
Can't seem to make it work with 6.50-16 tires and doesn't come up with the old sizes either. frown
V
V Offline
I went with 17" Wheel Vintiques steel wheels with vintage looking stainless steel hubcaps and modern Michelin tires. Looks pretty good.
I used 15x8 Blazer ralley wheels. No clearance probs. No rubbing on the tie rods.
Im using 15" Artillery Wheels now. Ralley wheels are available now if someone needs them.
Some sort of off-brand 215/85r16on original 16 inch wheels. No major complaints so far. There’s a little more design and texture on the sidewall than I like᠁but I was going for cheap. I think I ordered online shipped to Walmart.
Now that I see a pic of the 215/75r16 from Evan᠁I think that looks better. Not quite so tall.
1951 3100
Firestone M+S 215/70 R16 No unnecessary designs or junk on the sidewalls. They look like they could be from days gone by.
$94 each on Amazon
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
Anyone know of any 8-19.5 tires that look kind of old school? I just got commercial style ones but they're going to ride like a stone wheel. Probably last forever though.
1961 Chevy C40 Flatbed 261
Cooper 275R17 on outlaw 17 inch wheels
Otto, if you did not know if your order from Amazon they will ship to a local tire shop and it includes the mounting cost. Where I live they ship to a Tire Barn. I have not lucked in a while it was cheaper that.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.701s Queries: 17 (0.037s) Memory: 0.6747 MB (Peak: 0.7998 MB) Data Comp: Zlib Server Time: 2025-09-22 08:00:50 UTC
Valid HTML 5 and Valid CSS
