6 members (Brian Moore, ndkid275, Otto Skorzeny, klhansen, Chip O, Bwana-Jim), 83 guests, and 1 robot.
Topics128,034
Posts1,055,542
Members48,425
In my rear wheels where the brakes are located. I'm missing the lever that the E-brake cable attaches to.The lever is the part that spreads the shoes apart to manually activate the emergency brake. Does anyone know of a place to find these parts?
My truck is a 1953 3600 3/4 ton Chevy. Bendix brakes.
Elmo.
Moderator, Electrical Bay
If you look around you may find the parking brake parts share enough similarities that they'll interchange. A few years ago I came across a box of 1969 Chevy pickup brake parts. There were almost enough pieces to turn my parking brakes into the later self-adjusting type, but not quite.
~ Jon
What Jon said. The same design Bendix brakes were used up into the '70s. So a trip to a wrecking yard should score you the parts you need.
I believe you are correct. I have looked online up to a 72 C-20 chevy truck E brake parts to no end. Next up, the junk yard.
Elmo
Now I just found all the parts I need in a parts bin I had out in the garage.
Yay!!
Great, I can imagine your relief! all it takes is one little part and you are dead in the water.
Mike Barnes
1950 GMC 1-ton pickup
