1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | In my rear wheels where the brakes are located. I'm missing the lever that the E-brake cable attaches to.The lever is the part that spreads the shoes apart to manually activate the emergency brake. Does anyone know of a place to find these parts? My truck is a 1953 3600 3/4 ton Chevy. Bendix brakes.
Elmo.
| | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | If you look around you may find the parking brake parts share enough similarities that they'll interchange. A few years ago I came across a box of 1969 Chevy pickup brake parts. There were almost enough pieces to turn my parking brakes into the later self-adjusting type, but not quite.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: May 2015 Posts: 11,017 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,017 | What Jon said. The same design Bendix brakes were used up into the '70s. So a trip to a wrecking yard should score you the parts you need.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I believe you are correct. I have looked online up to a 72 C-20 chevy truck E brake parts to no end. Next up, the junk yard.
Elmo | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | What Jon said. The same design Bendix brakes were used up into the '70s. So a trip to a wrecking yard should score you the parts you need. Now I just found all the parts I need in a parts bin I had out in the garage. Yay!! | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Great, I can imagine your relief! all it takes is one little part and you are dead in the water.
Mike Barnes 1950 GMC 1-ton pickup
