| | | Forums66 Topics128,105 Posts1,056,545 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 73 PA OUTLAW | | PA OUTLAW Joined: Sep 2017 Posts: 73 | Just finished the bed floor on My 1954 chevy 3100 and it looks GREAT!! My question deals with the tailpipe heat sheild under the bed floor. I understand the tailpipe heat sheild go"s on theunderside above the rear axle . HOW MUCH clearence do I need between the Heatsheild and the tailpipe should I use HI -temp paint on the heat sheild ? How hot does it get ? dont want to set my bed floor on fire!!!!! THANK YOU ALL IN ADVANCE!!!!!!!!!!!!!!!!!! | | | | | Joined: May 2015 Posts: 11,105 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,105 | The heat shield installs so that air can flow thru between the wood and the shield (front to back). I doubt that if you get 1" or more of clearance between it and the tailpipe that you'd need hi-temp paint on it. Either way, I doubt you'll set your bed floor on fire.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | I would suggest you go to Mar-K's website and review the Heatshield installation instructions . It answers many of your questions. https://www.mar-k.com/PDFs/Instructions/heatshield.pdf
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | |
