4 members (MikeStone1953, 51 3804, jmmmn37, 1 invisible), 86 guests, and 2 robots.
Topics128,260
Posts1,058,322
Members48,485
Can anyone tell me if the 3 speed overdrive transmission is the same for both the 6 cylinder and the V8 on a 57 Chevy pickup? Thanks!
They will both fit. The only possible difference would be the length of the tailshaft which would require lengthening or shortening the drive shaft. But all of the Chev overdrives will bolt up to the clutch housing.
Thank you!
Curmudgeon
Curmudgeon
1957 Truck
Bottom transmission mounts are threaded on a truck (cars are not).
The OD option could be ordered to go with the 235, 261, 265 or 283 engines.
The kick-down switch bracket parts will be different between a Rochester B (I6) and the Rochester 2GC (V8).
4.11 ratio rear axle.
No difference in length between cars and trucks. Same gear ratios. Same drive shaft. There will be a difference on the side cover in the clocking position and the length of the shifter shafts between cars, trucks, and years.
Fred
Thanks everyone. Does anyone know where I can find one?
You can send me a PM
Curmudgeon
Curmudgeon
Have you checked ebay?
https://www.ebay.com/itm/324892710154
There are other parts needed to make this transmission work.
It case you didn't know, the early transmissions did not have synchronized first and reverse.
You have to slow down or stop to shift else you get gear grind.
I would definitely go with the later trans with synchro first gear. I have both, and for me the synchro trans makes driving a significantly more pleasurable.
don
The Saganaw SM326/BW R10Q is a better unit but was only used for 4 years so there are not many around and are priced accordingly.
They also have some unique differences, one of a kind solenoid and governor, different side cover configuration, and fine spline output shaft.
Fred
rfs56trk - did you get my PM?
I did and responded to it last week.
Apparently the message has disappeared from my inbox. Can I give you a call sometime? Thanks. John
Sure, sent another PM
