4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
#1431029 11/23/2021 2:18 AM
I want to verify what i have read on several post before i spent money. i have a 51 3600 with stock rear end 8 lug. From what i have read i can do a direct swap rear end with a 67-72 C20 rear end. Is that correct? Is the diff off set like my original? also do i have to make any adjustment to drive shaft? Thanks
1951 Chevy 3600
Riding in the Passing Lane
No. The complete rear end is not a direct swap. You can take the center section (often called a 3rd member) from the 72 on back & put it in the housing. The 67-72 C20 with v-8 & auto trans has 4:11 gear ratios. It is very desirable as it gives a better highway ratio. It is pretty rare though.
George
This belongs in the driveline section.
1972 Chevy c10 Cheyenne Super
As stated above, the third members will swap between the housings. 3/4 tons had the option of 4.11 gears from '65-'67, and that changed to a 4.10 gear option from '68-'72. There's a good bit of them out there. I've found three in the last few years just paying attention to what's being sold in the yards and on marketplace. It's an easy procedure. You unbolt the axle shafts and slide them out about 6". Unbolt your driveshaft from the third member. Then unbolt and remove the third member. That third member is pretty heavy though.
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
Crusing in the Passing Lane
Good idea to drain and replenish oil.
Ed
1 Offline
Good idea to have some sort of jack available. At least a floor jack and another person. It's that heavy.
1951 3800 1-ton
In the DITY Gallery
