| | | Forums66 Topics128,076 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | Hello all! My name is Dave, and I found a truck in my backyard (I really should mow more often) Anyway, I am trying to figure out what year and model it is. I have some pictures, and some figures (160 inch wheelbase, 12 foot bed, 7.50 X 20 tyres) and as near as I can figure, it is a 42-46 1 1/2 ton. But that is just a guess.
David C. Wilker Jr. USAF (RET)
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage gang, Dave - sounds like a good guess for starters, can you show us the pics? have you looked at the pics in the gallery here? if you can get the VIN number off the plate on the drivers door jamb, or maybe on the passenger side of the cowl under the back of the hood, someone here can help narrow it down and you can skip the mowin for awhile now, won't be any more trucks sprouting this season! Bill | | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | Thanks, Bill. I have submitted some pictures to the Gallery, including a scan of what's left of the ID plate. I can also email pics if you like.
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Here are the shots. Dave will have to identify some a little better. And these are big images so you can get all the details. Image One Rear window VIN Info Front left image Eagerly await your reply so we can get some info into the gallery for Dave! Thanks all. Peg
~ One of many.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ye olde vin cruncher sez 6YS04 = 1941 1.5T 160" W.B. made in Oakland CA, and being a Chev, that 6cyl must be a 216
Bill | | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | Thanks for the info, Bill. But if it is 41, wouldn't the passenger side door have the lock in the handle? This thing has a seperate lock cylinder. But it does have the 160" WB (I measured it). I suspect the engine is a 235, but I will double check that. That is, when the yellow jackets leave me alone. Ugh.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | There's a '41 1.5 ton just down the road from me in a junk lot that has the door lock beneath the passenger handle, not in it. In these old trucks, it's not uncommon to find them with swapped parts (like a '46 door on a '41 truck) or small features that deviate from what would be expected in a "factory spec" truck. The most reliable method to dating any old truck would be right from the Mfg. Plate serial number.. but that dosen't mean that some farmer didn't use a bumper of an AD and taillights off a .. >cringe< MOPAR. Identifing the engine size in your truck will require taking a look at the engine serial number located to the left, and just below, the distributor. Once you have the number, you can refer to the Inliners.org website page located here to determine the size. Early 216's and 235's look identical to me.. I don't know how a person could tell one from the other without knowing the serial number and looking it up. Take a rag and a can of WD40 out there with you.. if there's any WD left in the can once you've fended off the swarm of angry yellow jackets, it works great breaking up layers of crud and oil on the side of an engine! For all your 'VIN' Crunching needs, the VIN Decoder can be found here . .. oh yea.. WELCOME TO THE STOVEBOLT PAGE!!
| | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | Well, I (or "M") F129H is what is stamped in the pad on the engine. Let's see what THAT means.
| | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | Ok, more goofiness...The valve cover is the 4 bolt-in-edge type, but the side cover is short, and doesn't cover the spark plugs.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that makes it a later 235 fer sure, but the numbers don't compute with any thing here tho, for 41-57 Bill | | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | More info...I looked for an found the casting numbers for the block and head. The head says: B37 848 85, and the block is: 383 004 (1955-57 235) That would probably explain the 216 parts in the bed! Today has been a good day for learning stuff!
| | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | Which reminds me, if anyone out there needs any 216 parts...
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | The engine serial number decodes as follows: F=Flint engine plant 129=build date=January 29 H="Thriftmaster 235" used in 31-32-36-3800 series.
The year would be '57 based on the block casting number (should that be 3837004?) and the format of the serial number, which changed in '57 (the tocmp site has an error regarding '57 engine serial numbers). The head casting date code B37 (February 3, '57--a few days after the build date??) confirms the year if it is the original head to the engine. The block should have a casting date code, too, probably by the starter.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | I have nothing to add in the way of information but.. neat truck and welcome to the 'bolt. -W | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Yea.. so where are the pics, man?!
| | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | Did it run when it was parked?
| | | | | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Welcome to the Stovebolt, and particularly the Big Bolt meeting room.
The big bolts had a key lock separate from and below the door handle on the passenger side.
At least my '46 1-1/2 ton is so equipped.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
| | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | It did NOT run when it was parked, Lord knows if it ever ran. When my Father dropped it off (I wasn't here) he was steering it off the trailor. Well, without brakes, he got a longer ride than he thought he would. Drove all the way down the street! I asked him later why he didn't have the tranny in 1st or reverse, and use the clutch. He just looked at me, like, "Where were you when I needed help?". As to the door lock, evidence (VIN) is now pointing to it being a 41, and I thought 41s had integrated door handle/lock cylinders. But like Bill said, part swaps happen. There are some pics attached to an earlier post. Peg is working frantically to get a web page up in the gallery section. I can also email you pics privately if you like. Thanks for the good wishes!
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | FYI,
Working on the entire gallery page. Should be up in a day or two.
Peg
~ One of many.
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The rear window looks to be 42-46. | | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | I had heard someplace that the back window of a 41 was different, but I don't know for sure what it would look like.
| | | | | Joined: Jun 2005 Posts: 13 Junior Member | | Junior Member Joined: Jun 2005 Posts: 13 | QUESTION(S): Did these old boogers have power brakes? I could swear there is a control valve on the firewall, and a vac booster on the right frame rail!
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | My '46 2 ton has that booster looking thing on the right frame rail.. right in the neighborhood of where the "spicket" for the gas tank sticks out.
It was my understanding that it was some sort of vac assist to the brake system, but I really don't know for sure.. I just put fluid in the master cylinder, bled the brakes, and let sleeping dogs lie.
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Yep, power brakes were an option on the '41 1.5-tons.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the Hydro-Vac or Multi-Vac vacuum brake booster was standard on the bigger trucks - not "power brakes" as we know them today Bill | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | It is FINISHED (the gallery page that is) Dave\'s 1.5-Ton Let the healing begin. Peg
~ One of many.
| | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | Originally posted by Woogeroo: I have nothing to add in the way of information but.. neat truck and welcome to the 'bolt.
-W second that!
car nut for life!
