9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14310 08/08/2003 3:09 AM | Joined: Jul 2003 Posts: 26 Apprentice | | Apprentice Joined: Jul 2003 Posts: 26 | Would anybody may help me regarding the right spark plug and gap for it on these engines?. They all are on pick ups I am restoring. Does it make any sense to use an extension to the spark plug when heavy blue smoke shows up at the tail pipe?
Chevy'51 GMC '54 GMC '56 GMC '59
#14311 08/08/2003 6:44 AM | Joined: Oct 2001 Posts: 39 Member | | Member Joined: Oct 2001 Posts: 39 | Hey man whats up, well that sucks a little doesnt it.First off what truck do you have and secondly what engine is on it?
BIGGY
1965 CHEVY "BIG RED"
#14312 08/08/2003 10:21 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | This blue smoke "shows up" under what circumstances? How much smoke are we talking about here; a puff on takeoff or a James Bond accessory? Has this truck been sitting for the past decade or has it just started doing this after years of use/abuse?
Common "blue smoke" culprits are valve stem seals and rings. If that's where the problem lies, nothing you do to the plugs is going to help much. | | |
#14313 08/08/2003 3:37 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Lazy: They have an extension that is called "foulers" that screw in and then you screw your sparkplug into that. The only thing it does is help with not changing plugs so often. They work I have one in a cylinder on my 88 350. Sound like the above post: rings or seals. Nothing will help until you do that. popcorn The Truth is Out There (Good Luck) | | |
#14314 08/08/2003 10:05 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | AC-44 or 46. Gap= .035"
The only reason I'd try non-foulers is if the engine were fouling-up a plug very quickly.
I'd try a higher heat-range plug first. If the hotter plugs foul, then the engine is probably using so much oil that it needs to be overhauled. That's been my experience anyhow, with 216s and 235s.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#14316 08/12/2003 3:06 AM | Joined: Jul 2003 Posts: 26 Apprentice | | Apprentice Joined: Jul 2003 Posts: 26 | Thanks a lot folks for your answers. I am a new comer (You may have already figured out by now)on this field so I would try to have some rational answers for you: BIGGY.-GMC 54 Pick up half ton. no idea reagrding engine size. HEDGEHOG.-The smoke comes from the GMC 54, just recently purchased after being sited for at least eight years. Smoke came out when I started after those eight years. I changed oil previously. After some time running, about 20 minutes the engine died after a fowl. I could not restart it. POPCORN.- It has already a fowler on every spark plug. If in need of rings/ seals, where can I get them? FRANK54.- GMC54 currently has Champion J18C, no idea on the others. Somebody also told me to use Autolite 333 or so. I may use AC44 or 46 as per your comment. What may be be a hotter number?. OLDCARKOOK.- Thanks a lot for the manual copies, it solves some of my current questions. I will spend some time reading it.
#14317 08/12/2003 2:44 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If it's a GMC engine, the first 3 digits of the serial number should reveal the engine. Serial number is on a machined boss just aft of the distributor. Should start with 228, 248, 270 or 302. On AC plugs, the higher the number, the hotter the plug. Plug foulers are made to be used only on the plugs that are fouling, the can reduce fouling, but cost you some power from incomplete combustion.
Fred 52 3600 69 C-10
