8 members (Stewart2, 3B, Peggy M, Steelonsteel, moparguy, Millenimech, 2 invisible), 100 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#1431171 11/24/2021 10:13 AM
2 Offline
I put high build primer on the firewall and sanded it smooth. I rubbed through to bare metal a couple spots. But it just about ready for paint. I dont really want to spray the high build primer on the bare areas that I rubbed through to bare metal because I will have to sand everything again. Can I use a non sanding primer and then paint it. Thanks for any help
AD Addict & Tinkerer
You don’t have to paint everything again, just the bare spots. You will still have to sand them, but just lightly.
Phil
Project Journals
Stovebolt Gallery Forum
I'm using an epoxy primer that says it can be topcoated without scuffing within 5 days. But sanding your primer spots as Phil says isn't a lot of work.
