| | | Forums66 Topics128,022 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Was wondering if anyone has tried the “kerosene and baking soda” suggestion in the manual to service this valve? Mine is worn ( the hole shows sign of exhaust leak) but working and I’d like to keep it from seizing. I take it a slurry was made from these two and shot onto the valve shaft? Also have seen a suggestion to use graphite. I have Loc-Ease with graphite that might be an answer. Just looking for what others may have done to service the valve.
This is a ‘47 3100 AD 216 I’m looking at. | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | "Never-Seez" anti seize compound works well. It's a mixture of atomized aluminum and high temperature grease. I've used it to keep the 3-piece exhaust manifolds on Cummins Diesel engines from rusting together. Jerry
