3 members (GRNHydra, NJC, Otto Skorzeny), 60 guests, and 4 robots.
Topics128,064
Posts1,055,859
Members48,428
#1430830 11/20/2021 11:13 PM
I had a heckuva time removing the firewall grommet for the engine harness (1965 C10). Now I need to remove the plug and grommet that goes to the alternator/horn. Is there a trick to removing those things?
1965 Chevy C10 Longbed Fleetside
I've always sprayed grommets with WD-40 for install and removal. Never tried it but I could see see a heat gun or even hair dryer helping with old crusty grommets.
One last thought, brake fluid. I've had good luck revitalizing old rubber by giving it a long bath in brake fluid.
RonR
RonR
1970 340 Duster
1964 CJ5
RonR
Be careful with the brake fluid or as I call it "An Outstanding Paint Removal Fluid".
Bob said; Be careful with the brake fluid or as I call it "An Outstanding Paint Removal Fluid"."
Yep, that's a fact. If you use brake fluid on old rubber, be sure to do a good job wiping it off and drying before placing it where it will contact paint.
RonR
RonR
1970 340 Duster
1964 CJ5
Ex Hall Monitor
Ex Hall Monitor
If I'm reading the OP's initial post correctly he's trying to remove the grommet from the truck. It'll be difficult to put brake fluid on it and not get it on the paint. If I'm correct in how I'm reading it the rule of thumb I use is just cut the old one off and replace it with a new one if new grommets are available.
Thanks guys. Tiny I think I like your idea - cut out the old one
War Eagle1 I suppose you have gathered by now that brake fluid is too dangerous,just use dishwashing soap,or silicon (ignition )grease not much. Also learned from Jim Carter himself that hydraulic jack oil wont hurt rubber brake parts.
