7 members (Otto Skorzeny, Samantha, MNSmith, Phak1, cmayna, CATMAN, Gray_Ghost),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,850 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Hello, I need to replace the master cylinder on my 59 and would like to do the break line that runs accross the rear end . I ts a 3/4 ton so different from 1/2 ton . have not seen any repos. The one on now is home made, works but is ugly. Any ideas? | | | | | Joined: Feb 2019 Posts: 4,502 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,502 | You can buy a new master cylinder from Classic Parts. Here is a LINKThis would be a great time to upgrade to a dual master cylinder. It would require running new brake lines, but if you use CuNi (Copper Nickel) it can be bent by hand. It flares easily with a cheap flaring tool and now with your new skills, you can replace your brake line on the rear end and run it the way you like!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2007 Posts: 3,433 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,433 | There are several vendors that carry RePop brake lines, In-line Tube and LMC Truck are both good sources. I used a kit from In-line Tube for my 59', it was a direct replacement for the factory lines. I used the stainless tubing, harder to work with but they last forever. As Phil said this would be a perfect time to up-grade to a duel master cylinder.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Thanks the 36 rear is different,but making my own lines cant look any worse than what is there. Dont know about a dual master right now .I got a new one from classic to put on. where would i find the cuni lines? was thinking of the preflaired ones from parts store. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | You can buy the nickel/copper lines in 25’ rolls at every parts store or online. My ‘62 used 3/16 and was very easy to bend. Rent the double flare tool from O’Reillys or Autozone.
