4 members (FAST55, Bill Hanlon, Nick in Manitou, 50Chevy3100), 97 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
#1430621 11/18/2021 9:49 PM
Hello, I need to replace the master cylinder on my 59 and would like to do the break line that runs accross the rear end . I ts a 3/4 ton so different from 1/2 ton . have not seen any repos. The one on now is home made, works but is ugly. Any ideas?
AD Addict & Tinkerer
You can buy a new master cylinder from Classic Parts. Here is a LINK
This would be a great time to upgrade to a dual master cylinder. It would require running new brake lines, but if you use CuNi (Copper Nickel) it can be bent by hand. It flares easily with a cheap flaring tool and now with your new skills, you can replace your brake line on the rear end and run it the way you like!
Phil
Project Journals
Stovebolt Gallery Forum
Crusty Old Sarge
Crusty Old Sarge
There are several vendors that carry RePop brake lines, In-line Tube and LMC Truck are both good sources. I used a kit from In-line Tube for my 59', it was a direct replacement for the factory lines. I used the stainless tubing, harder to work with but they last forever. As Phil said this would be a perfect time to up-grade to a duel master cylinder.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Thanks the 36 rear is different,but making my own lines cant look any worse than what is there. Dont know about a dual master right now .I got a new one from classic to put on. where would i find the cuni lines? was thinking of the preflaired ones from parts store.
You can buy the nickel/copper lines in 25’ rolls at every parts store or online. My ‘62 used 3/16 and was very easy to bend. Rent the double flare tool from O’Reillys or Autozone.
